그래픽 카드를 바꿨는데요.메인보드를 갈아야될지?
418
정진혁님의 질문에 대한 답변입니다.
원랜 지포스4를 사용했고요 지금은 라데온9600으로 바꾸고 사용하고있는데요; 고사양 그래픽도 잘돌아가는데; 게임이 안깔리는 현상이 생겼는데; 그래픽카드 때문인지는 잘모르겠고; 유틸은 깔리는데; 게임은 깔리다 오류가 나는 일이 많이 일어나고요; 내동생말로는 포맷을 자주해서 하드를 바꿔야 된다는데; 지금쓰고있는 메인보드가
VIA 의 P4X266E-8235 라고 되있고
이건 내용인데;
SiSoftware Sandra
System
Manufacturer : VIA Technologies, Inc.
Model : P4X266E-8235
Mainboard
Manufacturer : Jetway
MP Support : No
System BIOS : 06/27/2003-P4X266E-8235-6A6LWJ19C-00
Chipset : VIA P4X266/A
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 768MB
Bank0/1 - A0 : None None None None DIMM 256MB
Bank2/3 - A1 : None None None None DIMM 256MB
Bank4/5 - A2 : Empty
Chipset 1
Model : VIA Technologies Inc VT8753 Apollo P4X266 System Controller
Bus(es) : ISA AGP PCI USB i2c/SMBus
Front Side Bus Speed : 4x 134MHz (536MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 100MHz / 2x 133MHz
Width : 64-bit
IO Queue Depth : 8 request(s)
Chipset 1 Hub Interface
Type : V-Link
Width : 8-bit
Full Duplex : Yes
Multiplier : 2/1x
Speed : 4x 88MHz (352MHz data rate)
IO Queue Depth : 9 request(s)
Logical/Chipset 1 Memory Banks
Bank 0 : 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Bank 2 : 256MB DDR-SDRAM 2.5-3-3-7 2CMD
Speed : 2x 134MHz (268MHz data rate)
Multiplier : 1/1x
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
Memory Module 1
Manufacturer : Samsung
Model : M3 68L3223FTN-CB3
Serial Number : F4047A9E
Type : 256MB DDR-SDRAM
Technology : 8x(32Mx8)
Speed : PC2700U 2.5-3-3-7
Version : 1.0
Date of Manufacture : 2005년 5월 12일 목요일
Set Timing @ 167MHz : 2.5-3-3-7
Set Timing @ 133MHz : 2.0-2-2-6
Environment Monitor 1
Model : Winbond W83697(T)HF ISA
Version : 6.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 33.0°C / 91.4°F
CPU Temperature : 40.5°C / 104.9°F td
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 2722rpm
CPU Fan Speed : 2557rpm
Voltage Sensor(s)
CPU Voltage : 1.49V
+3.3V Voltage : 3.30V
+5V Voltage : 5.00V
+12V Voltage : 11.86V
-12V Voltage : -12.69V
-5V Voltage : -5.00V
Standby Voltage : 4.61V
Battery Voltage : 3.22V
AGP Bus(es) on Hub 1
Version : 2.00
Multiplier : 1/2x
Fast-Writes Enabled : No
Side Band Enabled : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (44MHz)
Multiplier : 1/3x
LPC Hub Controller 1
Model : VIA Technologies Inc VT8235 PCI to ISA Bridge
ACPI Power Management Enabled : Yes
Delayed Transaction Supported : Yes
Delayed Transaction Enabled : No
Multiplier : 1/4x
Speed : 11MHz
DMA Multiplier : 1/2x
DMA Speed : 5MHz
USB Controller 1
Model : Acer Labs Incorporated (ALi) ALI M5237 OpenHCI USB Controller
Version : 1.00
Interface : OHCI
Channels : 2
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.00
Interface : OHCI
Channels : 2
USB Controller 3
Version : 1.00
Interface : OHCI
Channels : 2
USB Controller 4
Model : Acer Labs Incorporated (ALi) USB 2.0 Enhanced Host Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 6
Companion Controllers : 3
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
USB Controller 5
Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 7
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 8
Model : VIA Technologies Inc VT6202 USB 2.0 Enhanced Host Controller
Version : 2.00
Interface : EHCI
Channels : 6
System SMBus Controller 1
Model : VIA VT823x SMBus
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
PCI0 (1h) : PCI 32-bit +5V PME Full-Length Available (VIA Technologies Inc VT8633 Apollo Pro 266 CPU to AGP Controller)
PCI1 (2h) : PCI 32-bit +5V PME Full-Length Used
PCI2 (3h) : PCI 32-bit +5V PME Full-Length Available
PCI3 (4h) : PCI 32-bit +5V PME Full-Length Available
AGP (8h) : AGP 32-bit +5V Full-Length Available (Yuan Yuan Enterprise Co Ltd Radeon 9600)
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - PS/2 / PS/2
PS/2 Mouse : Mouse - PS/2 / PS/2
USB0 : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 2541 : FSB exceeds Chipset rated speed. Reduce FSB.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2520 : PCI bus speed is too high. Reduce FSB speed or FSB/PCI multiplier.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
바꿔야 된다면;; 좋은것좀 추천해주세요
저희 컴파라 제품을 이용해 주셔서 감사드립니다.
현재 고객님께서 쓰시고 계신 P4X266E-8235 메인보드는 VIA사에서 만
든 제품입니다. 이 보드는 FSB 533을 지원하며 메모리는 PC2100까지
지원합니다. 그리고 그래픽카드는 AGP 4X까지 지원을 합니다.
그리고 고개님께서 따로 장착하신 ATI9600은 AGP 4X, 8X을 지원합니
다. 이 그래픽카드는 고객님 메인보드에는 장착을 하여 사용른 가능
하지만 그래픽카드의 재성능은 발휘를 할 수가 없습니다.
그러니 고객님께서는 이점을 유의해 주시길 바랍니다.
그러니 고객님의 쓰시고 계신 CPU에 맞는 메인보드를 구입하여 사용
하셔야 됩니다.
