P4AL-800 usb버전및 전송속도가 어떻게 되죠?? |
김일천 |
05/04/20 10:12 |
2447 |
System Information
Time of this report: 4/18/2005, 21:52:45
Machine name: S-7ZYOJFH47OYG9
Operating System: Windows XP Professional (5.1, Build 2600)
Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: Korean (Regional Setting: Korean)
System Manufacturer: ALI
System Model: P4AL-800
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 512MB RAM
Page File: 330MB used, 919MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX 440
Manufacturer: NVIDIA
Chip type: GeForce4 MX 440
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0171&SUBSYS_00000000&REV_A3
Display Memory: 64.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7184 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/24/2005 07:32:00, 3973888 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: N/A
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/24/2005 07:32:00, 3454144 bytes
Device Identifier: {D7B71E3E-4231-11CF-A07F-0A2002C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0171
SubSys ID: 0x00000000
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e)
Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX
VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e)
Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX
VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e)
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10B9&DEV_5455&SUBSYS_54551849&REV_03
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmuda.sys
Driver Version: 5.12.0001.0038 (English)
Driver Attributes: Final Debug
WHQL Logo'd: Yes
Date and Size: 10/17/2003 12:52:06, 754560 bytes
Other Files:
Driver Provider: C-Media Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal,
Default Port
C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Microsoft GS Wavetable SW Synth [ Registry: OK
DirectInput Devices
Device Name: Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB | Vendor/Product ID: 0x10B9, 0x5237
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 15:08:42, 57600 bytes
| Driver: usbd.sys, 9/17/2002 12:36:32, 4736 bytes
Gameport Devices
+ PCI | Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/4/2004 16:36:42, 66688 bytes
+-+ | | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 15:08:22, 10624 bytes
PS/2 Devices
+ PC/AT 101| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 16:40:30, 49152 bytes
| Driver: kbdclass.sys, 8/4/2004 16:44:06, 23808 bytes
| Driver: kbdkor.dll, 8/17/2001 22:36:18, 8192 bytes
| Driver: kbd101a.dll, 8/17/2001 14:55:56, 6144 bytes
+ | Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 16:54:12, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 16:37:00, 22272 bytes
+ | Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run,
Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider:
DirectPlay Voice Codecs
Voxware VR12 1.4Voxware SC06 6.4Voxware SC03 3.2MS-PCM 64MS-ADPCM 32.8Microsoft
GSM 6.10 13TrueSpeech(TM) 8.6
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 19.8 GB
Total Space: 38.2 GB
File System: FAT32
Model: SAMSUNG SP0411N
Drive: D:
Free Space: 7.2 GB
File System: FAT32
Model: SAMSUNG SV4002H
Drive: G:
Free Space: 27.7 GB
File System: NTFS
Model: SAMSUNG MP0402H USB Device
Drive: E:
Model: HL-DT-ST CD-RW GCE-8520B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Korean),
8/4/2004 14:59:52, 49536 bytes
Drive: F:
Model: SPACE DVD-ROM KR-50A SCSI CdRom Device
System Devices
Name: NVIDIA GeForce4 MX 440
Device ID: PCI\VEN_10DE&DEV_0171&SUBSYS_00000000&REV_A3\4&BD4C42D&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.7184 (English),
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.7184 (English), 2/24/2005
07:32:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0016 (English), 2/24/2005
07:32:00, 32256 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0016 (English), 2/24/2005
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.7184 (English), 2/24/2005
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.7184 (), 2/24/2005 07:32:00,
540672 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.7184 (English), 2/24/2005
07:32:00, 5332992 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.7184 (English), 2/24/2005
07:32:00, 5537792 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.7184 (English), 2/24/2005
07:32:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.7184 (English), 2/24/2005
07:32:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10035 (English), 2/24/2005
07:32:00, 245760 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 2/24/2005 07:32:00, 165039 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 2/24/2005 07:32:00, 55444 bytes
Name: ALi 7101 Power Management Controller
Device ID: PCI\VEN_10B9&DEV_7101&SUBSYS_71011849&REV_00\3&13C0B0C5&0&19
Driver: n/a
Name: C-Media AC97 Audio Device
Device ID: PCI\VEN_10B9&DEV_5455&SUBSYS_54551849&REV_03\3&13C0B0C5&0&20
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (Korean), 8/4/2004
16:53:18, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (Korean), 8/4/2004
16:54:04, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (Korean), 8/4/2004
15:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English),
8/4/2004 15:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English),
8/4/2004 15:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (Korean),
8/4/2004 15:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004
16:54:04, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\cmuda.sys, 5.12.0001.0038 (English),
Driver: C:\WINDOWS\system32\udaprop.dll, 1.00.0002.0002 (English), 4/24/2003
14:29:08, 32768 bytes
Driver: C:\WINDOWS\system32\cmuda.dll, 5.12.0001.0107 (Chinese), 10/15/2003
19:37:32, 114688 bytes
Driver: C:\WINDOWS\system32\cmirmdrv.dll, 2/18/2003 19:26:28, 28672 bytes
Driver: C:\WINDOWS\system32\cmirmdrv.exe, 1.00.0000.0011 (English), 8/20/2003
19:46:52, 233472 bytes
Driver: C:\WINDOWS\system\cmids3d.dll, 1.00.0000.0000 (Chinese), 4/29/2002
16:04:40, 917504 bytes
Driver: C:\WINDOWS\system\cmicnfg.cpl, 1.00.0041.0002 (Chinese), 10/14/2003
12:52:32, 2301952 bytes
Driver: C:\WINDOWS\system\SmWizard.exe, 1.00.0001.0009 (English), 10/15/2003
17:26:44, 1454080 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2008 (English), 11/23/2001
13:08:20, 712704 bytes
Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2008 (English), 11/23/2001
Name: ALi PCI Fast Ethernet Controller
Device ID: PCI\VEN_10B9&DEV_5261&SUBSYS_52611849&REV_30\3&13C0B0C5&0&71
Driver: C:\WINDOWS\system32\DRIVERS\ALILAN.SYS, 5.01.2600.0130 (English),
4/13/2003 00:08:46, 29184 bytes
Name: PCI Device ID: PCI\VEN_10B9&DEV_5249&SUBSYS_00000000&REV_00\3&13C0B0C5&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (Korean), 8/4/2004
Name: ALi PCI to AGP Controller
Device ID: PCI\VEN_10B9&DEV_5247&SUBSYS_00000000&REV_00\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\ALiAGP.SYS, 5.01.2600.2110 (English),
3/4/2004 09:49:36, 29440 bytes
Name: Device ID: PCI\VEN_10B9&DEV_5239&SUBSYS_52391849&REV_01\3&13C0B0C5&0&7B
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English),
8/4/2004 15:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English),
8/4/2004 15:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Korean), 8/4/2004
16:53:28, 68096 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English),
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004
16:53:14, 7168 bytes
Name: ALi PCI to USB Open Host Controller
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&13C0B0C5&0&7A
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English),
8/4/2004 15:08:36, 17024 bytes
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&13C0B0C5&0&79
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&13C0B0C5&0&78
Name: ALi M5229 PCI Bus Master IDE Controller
Device ID: PCI\VEN_10B9&DEV_5229&SUBSYS_52291849&REV_C5\3&13C0B0C5&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Korean),
8/4/2004 14:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English),
8/4/2004 14:59:42, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\aliide.sys, 1.05.0001.0000 (English),
3/6/2003 11:32:28, 7311 bytes
Name: PCI Device ID: PCI\VEN_10B9&DEV_1683&SUBSYS_00000000&REV_00\3&13C0B0C5&0&00
Driver: n/a
Name: PCI Device ID: PCI\VEN_10B9&DEV_1563&SUBSYS_00000000&REV_20\3&13C0B0C5&0&18
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Korean),
9/17/2002 12:36:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 27136
bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:54 10496
bytes
d3d8.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 8192
bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 1689088
bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 436224
bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 825344
bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 590336
bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 350208
bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 47616
bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 34816
bytes
dplay.dll: 5.00.2134.0001 Korean Final Retail 9/17/2002 12:35:46 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 229888
bytes
dpmodemx.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 23552
bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/17/2002 12:35:46 42768
bytes
dpwsockx.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 57344
bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:40 30208
bytes
dpnsvr.exe: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:40 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 375296
bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:51:10 3584
bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:51:10 3584
bytes
dpvoice.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 209920
bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:40 83456
bytes
dpvvox.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 116736
bytes
dpvacm.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 35328
bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 60928
bytes
dpserial.dll: 5.00.2134.0001 Korean Final Retail 9/17/2002 12:35:46 53520
bytes
dinput.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 150528
bytes
dinput8.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 173056
bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/17/2002 12:35:44 44032
bytes
diactfrm.dll: 5.01.2600.0000 Korean Final Retail 9/17/2002 12:35:44 394240
bytes
joy.cpl: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:54:02 66560 bytes
gcdef.dll: 5.01.2600.0000 Korean Final Retail 9/17/2002 12:35:56 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:24 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 15:08:22 10624
bytes
dsound.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 367616
bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 1294336
bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 19456
bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 181760
bytes
dsdmoprp.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 72704
bytes
dmusic.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 104448
bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 28672
bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 61440
bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 181248
bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 35840
bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 105984
bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 103424
bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:12 82432
bytes
dx7vb.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 619008 bytes
dx8vb.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 1227264
bytes
dxdiagn.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:12 2113536
bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/17/2002 12:36:04 924432
bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 16:53:18 1028096
bytes
wsock32.dll: 5.01.2600.2180 Korean Final Retail 8/4/2004 16:53:32 31232
bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 16:53:10 70656
bytes
devenum.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:12 59904
bytes
dxmasf.dll: 6.04.0009.1125 Korean Final Retail 8/4/2004 16:53:12 495645
bytes
mciqtz32.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:18 35328
bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 16:54:04 148992
bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 16:53:18 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:14 20480
bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 08:53:22 221184
bytes
qcap.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:24 192000 bytes
qdv.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:24 279040 bytes
qdvd.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:24 384512 bytes
qedit.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:24 560640 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 16:52:06 733696
bytes
quartz.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:24 1273344
bytes
strmdll.dll: 4.01.0000.3928 Korean Final Retail 8/4/2004 16:53:28 246302
bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 16:54:04 199680
bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 16:54:04 848384
bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 16:53:16 120320
bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 16:53:16 338432
bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 16:53:16 755200
bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 16:53:16 200192
bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 16:53:16 183808
bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 16:54:04 154624
bytes
mswebdvd.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:22 201728
bytes
ks.sys: 5.03.2600.2180 Korean Final Retail 8/4/2004 15:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:54:04 130048
bytes
ksuser.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:18 4096 bytes
stream.sys: 5.03.2600.2180 Korean Final Retail 8/4/2004 15:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 Korean Final Retail 8/4/2004 14:58:38 5376
bytes
mspqm.sys: 5.01.2600.2180 Korean Final Retail 8/4/2004 14:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 Korean Final Retail 8/4/2004 14:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Korean Final Retail 8/4/2004 14:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 16:54:04 118272
bytes
msvidctl.dll: 6.05.2600.2180 Korean Final Retail 8/4/2004 16:53:22 1420800
bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 16:54:04 30720
bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 16:53:22 17408 bytes
wstdecod.dll: 5.03.2600.2180 Korean Final Retail 8/4/2004 16:53:32 50688
bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.02.0001.1335
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,,
ffdshow Video Decoder,0xff800009,2,1,ffdshow.ax,9.00.0000.0001
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
CoreVorbis Audio Decoder,0xff80000f,1,1,CoreVorbis.ax,1.00.0003.0605
Stream Splitter (DSM),0x00600000,1,1,DSMSplitter.ax,1.00.0000.0003
File Source (Dirac),0x00600000,0,0,DiracSplitter.ax,1.00.0000.0004
ffdshow Raw Video Filter,0x00200000,2,1,ffdshow.ax,9.00.0000.0001
Gretech MPEG Source Filter,0x00200000,0,1,GSF.ax,
ffdshow Audio Decoder,0xff800000,1,1,ffdshow.ax,9.00.0000.0001
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0004.0036
True Audio Encoder,0x00600000,1,1,TTADSEncoder.ax,1.00.0000.0038
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Matroska Muxer,0x00200000,1,1,MatroskaMuxer.ax,1.00.0000.0029
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Video Decoder (RealMedia),0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0044
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Moonlight MP4 Demultiplexer,0x00800101,1,2,mp4demux.ax,1.00.0005.41110
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
AAC Parser,0x00400000,1,1,aac_parser.ax,1.01.0000.0000
Audio Decoder (MPA),0x40000080,1,1,MpaDecFilter.ax,1.00.0001.0008
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Gretech Video Filter,0x00200000,1,1,GVF.ax,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
CoreFLAC Audio Source,0x00600000,0,0,CoreFLAC.ax,1.01.0000.0060
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Matroska File,0x00600001,0,1,Splitter.ax,
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stream Splitter (Dirac),0x00600000,1,1,DiracSplitter.ax,1.00.0000.0004
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0032
CoreFLAC Audio Decoder,0x00600000,1,1,CoreFLAC.ax,1.01.0000.0060
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
XviD MPEG-4 Video Decoder,0xff800008,1,1,xviddec.ax,2005.03.0006.0000
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
True Audio Decoder,0x00600000,1,1,TTADSDecoder.ax,1.00.0000.0157
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
Gretech AVI Source Filter,0x00200000,0,1,GSF.ax,
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
File Source (Ogg),0x00600001,0,0,OggSplitter.ax,1.00.0000.0019
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
TmVCodec,0x00200000,1,1,TmVCodec.ax,1.00.0000.0003
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
File Source (RealMedia),0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0044
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,5.02.0001.1335
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
Gretech Audio Filter,0x00200000,1,1,GAF.ax,
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
File Source (DSM),0x00600000,0,0,DSMSplitter.ax,1.00.0000.0003
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,1.00.0000.0003
Vorbis Encoder,0x00200000,1,1,,
.WMA9 Wrapper,0x00600001,1,1,TpDmoWrp.ax,1.00.0000.0004
Gretech OGG Source Filter,0x00200000,0,1,GSF.ax,
Ogg Multiplexer,0x00400000,1,1,,
DVBPortal HDTV TS Pump,0x00200000,0,1,HDTVPump.ax,9.00.0000.0000
Nero AAC Parser,0x00400000,1,1,NeAudio.ax,1.00.0004.0036
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
AVI<->AC3/DTS Converter,0x00400000,1,1,AVI2AC3Filter.ax,1.00.0000.0005
DirectVobSub,0x00200000,2,1,VSFilter.dll,2.03.0005.0002
Audio Decoder (RealMedia),0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0044
Stream Splitter (AVI),0x00600001,1,1,AviSplitter.ax,1.00.0001.0032
Gretech MKV Source Filter,0x00200000,0,1,GSF.ax,
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,2.03.0005.0002
ffdshow VFW Decoder Helper,0x00200000,2,1,ffdshow.ax,9.00.0000.0001
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Stream Splitter (Ogg),0x00600001,1,1,OggSplitter.ax,1.00.0000.0019
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AC3Filter,0xff800001,1,1,AC3Filter.ax,1.00.0002.0001
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
.MP43 Wrapper,0x00600001,1,1,TpDmoWrp.ax,1.00.0000.0004
.MPG4 Wrapper,0x00600001,1,1,TpDmoWrp.ax,1.00.0000.0004
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
DTS/AC3 Source,0x00400000,0,1,DTSAC3Source.ax,1.00.0000.0006
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
TurboPlayerFilter,0x00200000,1,1,TurboPlayerFilter.ax,1.00.0003.0001
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Gretech Network Filter,0x00200000,0,1,GNF.ax,
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0024
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
.WMV9 Wrapper,0x00600001,1,1,TpDmoWrp.ax,1.00.0000.0004
File Source (MO3/XM/IT),0x00400000,0,1,MODSource.ax,
DSM Muxer,0x00200000,1,1,DSMMuxer.ax,1.00.0000.0003
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
DC-Image Source,0x00200000,0,1,DCImageSource.ax,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
File Source (AVI),0x00600001,0,0,AviSplitter.ax,1.00.0001.0032
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Gretech MP4 Source Filter,0x00200000,0,1,GSF.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
TurboSource Filter,0x00200001,0,2,TurboSource.ax,1.00.0002.0006
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0024
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0032
Stream Splitter (RealMedia),0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0044
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
DC-Graphic EQ Filter,0x00800002,1,1,DCGraphicEQ.ax,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,,
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
True Audio Splitter,0x00600000,1,1,TTADSSplitter.ax,1.00.0000.0203
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Video Decoder (Dirac),0x00400000,1,1,DiracSplitter.ax,1.00.0000.0004
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.0000
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
WDM Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft 0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,9.00.0000.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Huffyuv v2.2.0,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Lagarith lossless codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
MSU Lossless Video Codec v0.5.6,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
x264 - MPEG-4 AVC/H.264 Encoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
True Audio Encoder,0x00200000,1,1,TTADSEncoder.ax,1.00.0000.0038
ffdshow Audio Decoder,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode1),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode2),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode3),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode1+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode2+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode3+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
ATSC A/52 Stream Decoder for MSACM,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
C-Media Wave Device,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM C-Media Wave Device,0x00200000,3,3,,5.03.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
C-Media Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: C-Media Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM C-Media Wave Device,0x00200000,10,2,,5.03.2600.2180 |
*장치관리자(위) dxdiag(아래)
P4AL-800은 usb2.0버전을 사용하는게 아니가요?
지원한다면 속도는 어느정도 되는지 알고 싶네요.
usb2.0 이었을때 700메가정도의 파일을 전송하면 대략 5~8분정도가
소요되는걸로 알고 있는데 제컴은 대략 20분정도가 소요되더라구여^^;
그래서 제 컴에 이상이 있나 싶어서 질문하는것입니다.
미디어게이트MG-25(삼성40G 5400rpm/8M)를 연결하면 비Hi-speed장치에
Hi-speed장치가 부착되었다고 나옵니다.
usb포트 전면2개 후면4개에 다 연결해 보았지만 속도도 똑같구
똑같은 메세지가 뜨더라구여.
다른 컴에서도 연결해 보았는데 (사양은 잘 모르겠지만)
이런 메세지두 안뜨구 5~6분정도만에 700메가정도를 전송해 주던데요.
어째서인지 알고 싶네요.
빠른 답변 부탁 바랍니다. |
안승현 |
05/04/19 |
1625 |
신선진 |
05/04/19 |
1669 |
