컴퓨터 문제가 생겼네요 |
정연섭 |
04/07/22 19:10 |
2114 |
파란화면이 뜨면서 이런 글이 나옵니다.
A problem has been detected and windows has been shnt down to prevent damage to your computer a wait operation, attach process, or yield was attempted from a DPC routine.
If this is the first time you've seen this stop error screen restart your computer. If this screen appears again,follow these steps:
check to make sure any new hardware or software is properly installed.
If this is anew installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continne, disable or remove any newly installed hardward or software, Disable BLOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components,restart yor computer, press F8to select Advanced startup options, and then select safe mode.
Technical information:
***STOP:0x000000B8(0x00000000,0x00000000,0x00000000,0x00000000)
Beginning dump of physical memory physical memory dump comlete,
contact your system administrator or technical support group for further
이런 메시지가 뜨는데요 컴파라에서 컴사서 한지 2틀 바께 안됬는데--;;
문제 해결좀 해주세요.
제가 컴터에 대해 잘모르거든요..
강현석 |
04/07/22 |
1403 |
김창겸 |
04/07/22 |
1608 |
