블루스크린입니다. 해결해 주세요. |
이융배 |
04/01/03 6:23 |
1699 |
A problem han been detected and windows han been shut down to prevent damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this os the first time you've seen this stop error screen, restart your computer. again, follow these steps:
check to make sure any new hardware or software is properly installed. If this a new installation, ask your hardware or software manufacturer for ant windows updates you might need.
If problems continue, disable or remove any newly intalled hardware or software. Disable BIOS memory option such as caching or shadowing. If you need to use safe mode to remove or disable compon ents, restart you computer, press F8 to select adwanced starup options, and then select safe mode.
Technical information:
****Stop:0X000000D1 (0x00000014,0x00000002,0x00000001,0xF9DA6327)
*** NDIS.SYS - Address F9DA6327 base at F9D94000, Datestamp 3b7dc561
Beginning dump of memory
physiccal memory dump domplete.
contact your system admini strator or technical support group for further assistance
위의 내용이 제 컴퓨터에 뜨는 블루 스크린입니다.
컴퓨터 사양은
PARA 하이엔드 1700 제품이고요
펜4 인텔 셀 1.7(노스우드 웰라멧)
삼성 256 DDR PC2700
보드는 AsRock Dream533GX Slim
그래픽 SiS 650GX DDR32(내장)
사운드 C-MEDIA 97 AUDIO (내장)
송진영 |
04/01/03 |
1341 |
양경모 |
04/01/03 |
1324 |
