부팅시 계속 파란화면이 나오네요.
장유정
03/06/01 9:58
1402
A problem has been detected and windows has been shut down to prevent damage to your computer
DRIVER_
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you`ve seen this stop error screen,
restart your omputer. If this screen appears again, follow these steps;
check to make sure any new hardware or hardware or software is properly installed,
if this is a new installation, ask your hardware or software manufacturere
for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software, disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup options, and then
select Safe Mode.
Techinical information:
*** STOP: 0x0000000A (0x81fc0af8, 0xc0000032, 0x00000000, 0x00000000)
이라는 메세지가 나와서 포멧하고 다시 XP를 설치했는데요...
데몬3.33, 네로5.0, V3, 알집, 인터넷만 연결하고 다시 시작을 했는데 또 이런 현상이 나오네요.
해결좀 해주세요...
참고로 여기서 산 컴파라 AMD데스크탑임
이진우 03/06/01 1220
진용주
03/06/01
1131
